Hallo everybody,
can someone recommend me a consumer or semipro projector wich makes a large picture on a short projector to wall distance?!
Greeetz
									Searching a projector - Short distance big screen.
 Do you like outlines? Easy Outliner on Juicebar Re: Searching a projector - Short distance big screen.
there are interesting models from Benq (2500-3500 lumens, 800x600 or 1024x768) , and also saw an Optoma (3200 lumens, 1280x800). They always have an "ST" in their product name, which means "short throw". I think these models are affordable and okay so far. (They have no Filters to clean but other projectors in this price class also don't have Filters).
there are surely other Manufactors too (think acer also has an "ST"-series), but the most interesting models i think are the benq mx613st and optoma EW605st
Hey...thx HerrNieDa....ST was a very good information for me!
while I was taken a closer look on your recommends...I found another model wich should fit...
[link removed] what do u think? any "Haken"?
greeetz
greeetz
Reason: link removed at the request of beamershop dot net
also looks very nice, but have no experience with infocus.
The best case you can have is to know a person who can service/clean your beamer
... the best thing in my temp case is that I don't search a projector for myself....A club want me to recommend them some equip wich is suitable to their ideas! - THEY -HAVE- TO CLEAN
greets
									greets
 Do you like outlines? Easy Outliner on Juicebar - Tschoepler
from the manufacturer's pdf:
projection distance 0,75 m - 1,65 m
projection size 1,23 m - 2,7 m
I don't know if these are min/max values but it's quite small, isn't it?
so maybe this is the "Haken" :p
- Tschoepler
ja mein herr,  Nie Da nachgelesen, have you?
 I should go to bed…
U MUST LESEN! not me :pTschoepler wrote:ja mein herr, Nie Da nachgelesen, have you?I should go to bed…
just compare the wide range models u think which are in budget...
maybe a bigger, heavyer beamer is better for installations - just a thought
Yes große projector super is! But recht expensive! We will sehen..... perhaps at the end it MUST be a Barco oder Christie with changeable lenses.
greetz
									greetz
