Mixing streaming video from the internet
KevinC
Post by KevinC »
I am trying to mix some video content live from the internet. There are a few live webcams on earth cam that I want to incorporate into my next project and I cant seem to find a way to do this. Ideas?
HerrNieDa
Re: Mixing streaming video from the internet
Post by HerrNieDa »
second computer and video mixer/grabber ;)
maybe you can run it from 1 computer with second outputscreen for inet-streams and mix them via mixer or grabber....
don't think there's a useable screen-grab solution which works as resolume source...
ehm....ehm... I know how it wooooorks...I know how it wooooorks...!!!! :D
-U may need two screens plus the ammount of your outputs-
One screen shows u the Resolume interface..on the other screen you place all the webcamwindows you want to mix with.
Now u need a vitual webcam software like "Fake Webcam" or "Vitual Cam" or...or or or
These tools are simulating a windows systemwebcam wich can be used in resolume like any other source.
I dont know exactly wich v.cam software gives u the possibility to define a desktoparea to capture from.... but I know..some do! So..all u have to do know is to define the desktop capturearea with your webcamwindows.
Insert some copys of the v.cam source in resolume to your composition...and crop, scale or position them just the way u like.
HaveFun!
Greetz
pfelberg
Post by pfelberg »
cosmowe wrote:ehm....ehm... I know how it wooooorks...I know how it wooooorks...!!!! :D
Greetz
Ok. Those are PC or Mac?
...there will be versions for booth.
...give google a try! ;)
greetz
rxfromparis
Post by rxfromparis »
for pc try Xsplit :)
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000 :))
nizeone! :P
KevinC
Post by KevinC »
Thanks, the virtual webcam sounds like a brilliant way to get that to work. Look forward to trying it out.
Thanks,
-K
