Columns
TrickyDicky
Columns
Post by TrickyDicky »
columns can be triggered but not activated.
No matter which column I choose, the column options (New, Insert, Duplicate and Remove) are only applied on column 1.
this is what beta testing is for. ARENA is fabulous!!!
Re: Columns
Aah yes you are right the Column application menu is not updated after clicking a column. We usually right click the column to open the column menu so we did not notice this. You can do this as a workaround for now. Thanks for spotting 7 reporting this!
TrickyDicky
Re: Columns
Thanks, works great.
