hey resolume-team!
I just encountered a lot of crashes using midi. here's an example that I can reproduce all the time: create a new composition, load one of the example clips and assign the clip-opacity to a knob on my midicontroller. works fine. then copy that clip another deck, load that clip to one layer and turn the assigned knob. avenue crashes. Playing a bit around I found out, that selecting other clips or empty clips first and then selecting the copied clip would prevent avenue from crashing sometimes, but it will crash again if you just move the clip around in the deck and select it again.
regards flo
p.s. I'm on a mac book pro, os 10.6.8
lots of midi-crashes
______________________________________________
Sys specs:
Arena 7.14.1 / MacBookPro9,1 / NVIDIA GeForce GT 650M / OSX 10.15.7
Sys specs:
Re: lots of midi-crashes
Hi flo,
I can recreate your midicrash too....
System is a Win7 PC.
I had send my logfile out of R4Arena to ResolumeHQ. I think it would be good if you also send your log.....
Greets
Greets
Do you like outlines? Easy Outliner on Juicebar Re: lots of midi-crashes
done!cosmowe wrote:Hi flo,
Tim Walther
- Team Resolume
Ha thanks, we heard some noises about these midi crashes but weren't able to reproduce them. This is great, thanks a lot!
seems like the poblem is solved in beta2, yeah!!
thanks a lot!!
flo
thanks a lot!!
flo
Sys specs:
Sys specs:
