resolume on dell inspiron 8000
sanfroi_
Post by sanfroi_ »
Has anybody tried resolume with a Geforce2Go on a laptop inspiron 8000, because when I try the dual monitor mode, it goes really slow on my second monitor.
And by the way what is a CreaVision scan line converter?
Thanks for all.
Yes this speed problem only ocurs on win98, on win2o00 there is no speed problem, but then you cant use the tv-out ... a friend of us also has the dell inspiron 8000 with the Geforce2Go and it is very very fast! (on win2000) ...
we are working on a solution (overlay surface) for the dual monitor setup that looks VERY promising, faster, easier, a whole lot better ...
a scan line converter converts a VGA signal (that goes from your videocard to your monitor) to a tv (composite/s-video) signal so you can show the image on tv screen on stead of a computer monitor. CreaVision is a sertain brand of scanconverters.
frank_
Post by frank_ »
Hi Bartholomew,
You got a scanconverter from Creavision yourself ?
no ... i,ve looked but it does not seem to be available in the netherlands ...
