resolume 3.3.2
pleiadian
resolume 3.3.2
Post by pleiadian »
I still have resolume 3.3.2 but when I start the program it works fine but after several minutes the program jammed. No files can be put in the columms anymore and when there a some bigger files edit to the layer the program also stops playing.I never had this problem and I never changed my setup. I also put the newest drivers and codec to my set even the resolume codec but the problem is still there. :(
Re: resolume 3.3.2
Did you already sent us the log file with the feedback form in the preferences? That way we can easily have a look and hopefully see what is wrong.
pleiadian
Re: resolume 3.3.2
Post by pleiadian »
I just reinstalled resolume and everything works fine!! Yes!! :D It doesn't matter me anymore what went wrong but the program is working!!
