Maybe in ver. 4 you'll enable a more detailed Test Card for the output with grids and circles (and a logo would be nice) like Dataton Watchout to make the edge blending process easier and more accurate?
just an idea...
Output Test Card
Re: Output Test Card
+ 1 !!!!!!!!!!
We are working on better testcards, if you have some more ideas of how your desired test card should look like let us know.
a bunch of nude girls hugging Resolume's logo? you can put in a grid for accuracy...
dirtyjohn_lv
something similar?
- Attachments
- PM5644-1920x1080.png (16.72 KiB) Viewed 19789 times
That's not enough to do edge blending....
like this?
- Attachments
- Gradients.jpg (209.63 KiB) Viewed 19775 times
- Phase.jpg (210.11 KiB) Viewed 19775 times
- PixelRasterFine.jpg (403.49 KiB) Viewed 19775 times
- Softedge.jpg (100.64 KiB) Viewed 19775 times
Do you like outlines? Easy Outliner on Juicebar Re: Output Test Card
Yes, exactly like this. This is a really pro solution...
I've downloaded all the patterns from their site...
Thanks Cosmowe !!!!!
