getting files to play without jitters
mk-ultra_
Post by mk-ultra_ »
so far the only file type if gotten to work in resolume are mpgs and they play with a jitter....avi, and mov wont play i either get a white blank or the program starts repeating the names of other sources over and over again.
ive read through the forum and im trying to figure out if this is a codec problem or should i try changing the file types with dr div-x?
any sugesstions?
mk-ultra_
Post by mk-ultra_ »
ok so i see why my quicktime files are turning out white...and i saw the warning on div-x so heres an add on to the above....
because i use studio 9 to capture with all my files are mpg....i have to use dr-divx to change the file type so i can work on them in premier...once i export from premier will its codec change the problem of the dr-divx modified files from workin in resolume or is it going to continue to be a problem?
AlexEtJeremy
Post by AlexEtJeremy »
you can also try : Canopus ProCoder
[Edited on 13-10-2004 by AlexEtJeremy]
SuperficiaL
huh?
Post by SuperficiaL »
Hi mk-ultra,
do i understand u correct? i mean that your premiere doesnt play *.mpg ?
because i never had this problem, and im using premiere for a long time now...
but your issue sounds like a codec issue to me.
make sure u have the right codecs installed, i recommend indeo 5.1 or 5.2...
HERE
is a file i uploaded for u (or other people) who need codecs and are too lazy to search for them ;)
be prepared to spare a few minutes because the file is almost 45 MB....
greetz SuperficiaL
