multiple compositions
timdas
Post by timdas »
hello
i'm new to Resolume and i think it's a great program but before i buy the equipment and the software i want to ask you if it's possible to achieve what i want:
PC: AMD X4 processor + 8GB ram + 2x PowerColor Eyefinity 6 /w 2 gb ddr5 Video Card - > 12 Minidisplay Output -> using 10 XGA Videoprojectors + 2 PC monitors
OS: Win 7 64 Bits
Can this system using Resolume 4 have a 4x1 composition + 5x1 composition + 1 different output + the rest of the displays to remain in desktop mode at the same time?
What version do you recommend ? arena or avenue ?
thank you
Basic
Re: multiple compositions
Post by Basic »
I dont know if this will be possible. Ideally when running Resolume its better to run from 1 card instead of 2 or even more. any chance of using a mixer or something to distribute additional signals.
Ive noticed this thread is from a little while ago. Have you bought this system? What has the outcome if any been?
HerrNieDa
Post by HerrNieDa »
which ati card you exactly have?
i heard that the 5870 chipset with 6 display port doesn't work with all outputs at once!
tested a ati 6970 with 2xdvi and 4xdisplay port, and it worked...
we also connected 2 matrox triple heads for extra outputs, so we hat 9 outputs...
but the performance was quiet lame, we hat to set the resolution to 640x480 on every screen in windows to get a stable framerate!
i use a gtx 285 combined with 9600 and 9500 cards for extra outputs which performs better...
had 8 outputs @ 1024x768 (at my nvidia card it doesn't seem to matter which monitor resolition i use) and i could run about 6 layers with framerate over 25fps!
don't know why the older gtx 285 seems to perform better, even with extra graphic cards...
my suggestion is the 512bit memory interface... the only point where the gtx 285 is better than the ati...
also may the drivers/cards from nvidia are better for massive multiscreening :D
also the graphic memory is smaller on my nvidia card compared to the 6970!
the tests were in resolume 3, with the 6970 we started the beta of arena to try a 8192x768 composition and the performance was much slower than in r3 with 4096x1536! don't know if it's better now in the final version!
maybe the new 7970 can handle 12 monitors with good resolution and performance (384 bit)
beside this card i would suggest the gtx 580 which has also 384 bit...
the new gtx 680 has only 256bit and i bet this card is slower in resolume than the gtx 580
the best solution should be using 2 computers... will work for sure and you can sync it via osc/midi ;)
i bet a gtx 580 with extra nvidia 520 cards and matrox triple heads to get the output you want should be the fastest solution for a single solution!
Stickygreen
Post by Stickygreen »
HerrNieDa wrote:which ati card you exactly have?
I have a HD5870 eyefinity 6, and I can say on my system all 6 outputs work with Resolume 3, and Resolume Arena 4
HerrNieDa
Post by HerrNieDa »
okay.... just heard that the outputs were not working with the first drivers/firmware when the card was new.
Nice to hear that it seems to work now :)
Shorties
Post by Shorties »
To use more then 2 outputs on the 5870, from what I understand, (I have a 6870 so it may be different) you need to use actual display port devices, or "Active" display port adapters such as this one: http://www.amazon.com/Accell-B087B-005B ... 918&sr=8-1 or this one for mini display port: http://www.amazon.com/Accell-B087B-006B ... 976&sr=1-3
Passive adapters do not work past two outputs total attached to the card.
Stickygreen
Shorties wrote: To use more then 2 outputs on the 5870, from what I understand, (I have a 6870 so it may be different) you need to use actual display port devices, or "Active" display port adapters such as this one: http://www.amazon.com/Accell-B087B-005B ... 918&sr=8-1 or this one for mini display port: http://www.amazon.com/Accell-B087B-006B ... 976&sr=1-3
This is true with any ATI video card that has more than 2 outputs. I really don't understand why passive adapters are even available..?
I have all VGA output adapters, going into a Kramer matrix, it works well.
