What's best Capture device for Resolume 4 ?
slimus
Post by slimus »
What's best Capture device (composite/VGA/DVI) with low latency for Resolume 4.0.0 ? and fully compatible (tested)
Epiphan VGA2USB: don't work :(
Pinnacle 500 PCI: work perfectly :)
Terratec Grabby: work perfectly :)
BlackMagic Intensity Pro: Work but not with all device, the quality is poor with some laptop or not work some HDMI devices, work perfectly with 5D Mk II
HerrNieDa
Re: What's best Capture device for Resolume 4 ?
Post by HerrNieDa »
KNC One TV Station: works, only WindowsXP drivers.
Pinnacle 110i PCI: works (little bit more delay than KNC One/Blackmagic and also little less quality)
Pinnacle Studio USB700: works, maybe a little more latency than pci versions!? also sends through (at least composite) to the output of the card.
AVER-Media Capture HD: works quiet well, latency is quiet high, 720p won't work only 1080p (tested in R3)
Blackmagic Intensity Shuttle USB 3.0: works perfekt, USB 3.0 NEC/Renesas Chipset and compatible Mainboard needed!
