Resolume 4.1 Released!
We rarely are as excited about an update as we are about this one. Resolume 4.1 comes guns blazing with new additions to the arsenal, and shows everyone there's a new sheriff in town. So strap on your boots and put on your cowboy hat, because here we go!
By popular demand we added masking and cropping to the Advanced Output of Arena.
Also you can now route layers directly to slices, saving composition real estate and generally making your life easier.
Syphon is now natively supported on MacOSX. No more mucking about with 3rd party plugins. Just enable it via the preferences and check them thumbnails!
You can drop the bass like Paris with the new AV example set by Dan Wise.
With the new Layer Router you can now create a clip that takes the input from any layer below. For instance you can take layer 1 and and display it again as layer 4 but perhaps smaller or with a different effect. This is also really handy to create picture in picture compositions. Because the world needs more picture in picture effects.
This is a long wish come true. Like, over 10 year wish come true. Ever since Composite Station, we wanted to have a Japanese version of Resolume, and now that dream has finally come true. Konichiwa, Resolume-san! Thanks to the Projection Mapping Association of Japan.
Besides that of course there's a bunch of improvements to help improve your workflow and the ever important bug fixes. Check the full list below, or head over the download page: http://www.resolume.com/download/
New Features & Improvements
Draw mask & crop shapes in advanced output (Arena)
Direct layer input to slices in advanced output (Arena)
Reorder slices & masks by dragging & dropping in the list (Arena)
Native Syphon Input & Output (Mac)
Direct layer input to other layers via router source
Blackmagic capture speed and image quality improved!
Japanese translation and interface
Russian translation and interface
Support for 14 bit Midi via Pitch Bend
Show time remaining on clip timeline (click the time to switch between two modes)
Stop MIDI mapping with the escape key
Drop an effect directly on a layer or composition
Play once & hold for AV clips
Number of steps and Step size values for relative MIDI controller
New AV demo clips by Dan Wise
New B&W mixer
Fixed Bugz
[FIXED] Some plugins do not load on OS X 10.5
[FIXED] Some mixers do not load on win 7
[FIXED] DMX channel number sheet has been updated (again)
[FIXED] Crash with using some AV clips
[FIXED] AV clip set to play once and hold switches back to play once
[FIXED] MIDI out on APC40 makes the slider get stuck on min or max
[FIXED] Crash when triggering a column while low fps
[FIXED] Right click to reset layer AV slider no worky
[FIXED] /2 *2 buttons for BPM sync are not mappable
[FIXED] SMPTE Crashes
[FIXED] Crash when changing composition resolution
[FIXED] USB DisplayLink devices don't work (cause crash on startup)
[FIXED] After triggering a column the clip panel shows the wrong clip
[FIXED] Preview with SHIFT Arrow Keys does not show the clip in the preview monitor
[FIXED] Parameter reset by right click does not work on the name of the parameter in the advanced output
[FIXED] Crash when moving QC clip with parameter linked to audio FFT
[FIXED] Memory leak on shutdown
[FIXED] DMX shortcut for select deck is not remembered
[FIXED] Closing Resolume when QuickLook is open causes crash on shutdown
[FIXED] Add date to Screenshots file names instead of all the 1's
[FIXED] Decks disappear
[FIXED] CMD + A select all clips but does not show multiclipsettings panel
[FIXED] AV slider is not sent via OSC out when V slider is moved
[FIXED] Layer direction shortcuts (MIDI out) are not sent out correctly when clip is in ping pong mode
[FIXED] Column names are disappearing (again sigh!)
[FIXED] After relocating, resolume jumps back to first deck...
[FIXED] PNG image without extension causes crash when added as mask
[FIXED] Input field calculations do not work in the composition settings window
[FIXED] Load folder from Finder
[FIXED] OSC /activeclip/quicklook/0 does not turn quick look off
[FIXED] Closed Decks are coloured too dark
[FIXED] When you drag something over a clip, select the clip for easier drag & drop behaviour
[FIXED] Layer name label is midi mappable
[FIXED] Switch to 2 property panel layout when "Show layer property panel" is disabled and the layout is set to 3 panels
[FIXED] Video panel is unfolded by default (to keep Freek sane. Relatively speaking.)
Resolume 4.1.1 bug fixes:
[FIXED] Potential crash when using composition MIDI mapping
[FIXED] Composition MIDI mappings duplicated when switching decks
[FIXED] Serial number registration only valid for one user
[FIXED] APC40 controller dial has incorrect range
Re: Resolume 4.1 Released!
...In Germany we would say:
Shorties
Post by Shorties »
Ahhh this is so awesome. I'm loving the features of the native syphon support. Congrats Resolume team on another awesome release! :D
vj granda
Post by vj granda »
Thanks Resolume Team. Now R4 is in another level...
subvert
Post by subvert »
cosmowe... PLEASE! NEIN! :roll:
hahaha...I tried to find the "I Like" button from your post....no luck so far. ;)
theLABVisuals
Post by theLABVisuals »
Excellent work to all! You've squashed a majority of my personal annoyancies with 4.0.1. Cheers!
Tony
GuruMeditation
Post by GuruMeditation »
Is there a way to zoom in in the advanced output window ?
When u have a lot of slice in a big screen (triple head for example...), it is just impossible to manage correctly.
Also, point magnetism like in IRmapio would be great !
pupdogg
Post by pupdogg »
Can u please please please incorporate audio to MIDI clock feature similar to Wavesum products right into Resolume? That would be awesome!
pfelberg
Post by pfelberg »
congrats!!
