Flash Games
CRGxxx
Flash Games
Post by CRGxxx »
Hi All
Are flash games playable when running across multiscreens in Resolume??
If so can anyone recommend where to download flash games.... All the ones I find have pc installers or embed in browser etc.
Cheers
CRGxxx
pfelberg
Re: Flash Games
Post by pfelberg »
No matter if they are Flash games or applications, I was never sucessfull to make them work within Resolume.
But, if you mean a full screen usage and no mixing with Resolume content at all, there´s a simple solution:
I run all my flash games and applications in my mac / pc side, while running Parallels.
I move the Flash player window to the 2nd monitor output position (>>>>> to the right) and then "CTRL + F" to make it full screen.
Then it is just like multitasking windows - but for the output ; ) Whenever you select your flash player (option +tab on Mac I guess) for active application, Resolume output will be overlayed by your flash game content.
Humm... that makes me wonder... is Parallels Syphon friendly?? :idea: :D :D
vjsjarcie
Re: Flash Games
Post by vjsjarcie »
Some time ago I programmed a little simple flashgame (pong) to run in Resolume itself.
Assigned the controls to midi-knobs, en there you go.
It worked, but I never really finished it.
Just an Idea...
CRGxxx
Re: Flash Games
Post by CRGxxx »
Pong is actually the sort of thing i'm after.
I reckon it will be great fun in our Igloo 360 domes.
Do you still have a version??? Could we try it??
Craig
Thelooca
Re: Flash Games
Post by Thelooca »
I'm waiting for this: http://openemu.org/ to happen... Should have syphon because it wil run in quartz composer.
vjsjarcie
Re: Flash Games
Post by vjsjarcie »
I only could find the .swf file.
If i find the .as and .fla file i'll post it also.
But you 're also free to decompile it and change it to your needs.
These are the parameters you can use :
Hope you have fun with it.
pong.rar
(22.2 KiB) Downloaded 981 times
CRGxxx
Re: Flash Games
Post by CRGxxx »
Wow thanks... if/when we get it going in the dome I'll post some pics..
Thanks very much.
Craig
