bizarre quartz resize issue
mowgli
Post by mowgli »
I have a quartz patch that up to this point was working absolutely fine displaying as intended.
If I put this SAME patch in a different folder and load it into resolume it is displayed oversized, i.e. it overspills in my comp however many times I press "scale to fit composition".
As I've said EXACTLY THE SAME FILE displays differently depending on which folder it resides in ?!?!
mowgli
Re: bizarre quartz resize issue
Post by mowgli »
somehow it's all working now, I'm happy but even more confused :b
