Various Navigational Ideas
fulleffekt
Post by fulleffekt »
Resolume ideas:
Adding A Delete Button (Backspace on Mac, DEL on windows)
Undo and Redo options < I know where you guys stand with this feature Joris.. Ive already read the thread below on Undo options.
Multiple clip drag.
When you copy and paste tracks from multiple layers, it creates a new layer above..
Can this be changed so it doesnt create a new layer above? :)
The ability to drag your decks left and right, changing the order.
Deck Export function, where it takes the exact clips in a deck and exports/copies them into a designated folder while keeping the original file format, etc.
Handy for switching projects to different computer systems.
Select multiple columns, shift them left and right or delete them
\\\ Hope this input helps, perhaps you've already been asked for some of these!
Have a good one
-Mike
fulleffekt
Re: Various Navigational Ideas
Oh and perhaps some kind of Fade In/Fade out effects to set at the beginning and ending of clips? This one might be a bit difficult. Thought Id bring it up anyways :ugeek:
mfo
Post by mfo »
+1
(well, fade-in/out might be unnessesary^^)
(and of course a deck export funtionality would require a deck import functionality as well)
+ a key for adding a column / removing a column
