blending mode: divide?
sherwin00
Post by sherwin00 »
Hi all,
I'm new to Resolume. I have something specific in mind (see attachment) and I need the 'Divide' mode as featured in After Effects and Photoshop. I'm hoping someone somewhere has made this patch!?
In the attached example, I used Divide to blend the geometry into the stars. The geometry interacts with the changing brightness values in the stars. If anyone knows how to replicate this in Resolume your help would be much appreciated!
anim 02.tiff
anim 02.tiff (1.42 MiB) Viewed 6821 times
sherwin00
Re: blending mode: divide?
Post by sherwin00 »
guys, really need help with this. If anybody knows how to replicate Adobe's divide blending mode please let me know !
Rene
Post by Rene »
Can you explain what divide does. Maybe post the two inputs and the output as well.
I don't have Adobe products installed, so I'm not familiar with this blend mode.
edwin
Post by edwin »
This blend mode simply divides pixel values of one layer with the other.
http://en.wikipedia.org/wiki/Blend_modes#Divide
Well that doesn't sound that difficult ;-), i'll give it a shot.
edwin
Post by edwin »
Are you working with a Mac or PC, i have a fisrt version to test with. It seems that a Divide is a dodge with inverted top layer. So i made the plugin and it seems to work but i'm not sure though if it works as it should.
