Save as location choice
Trypta
Post by Trypta »
First I would like to say thanks for the great software. I've just purchased Resolume and think it is excellent piece of software.
I've just recently found that their is no way to save your files in any other location but the "Documents/Resolume" Arena folder. Could a simple save as with a file browser be added? I personally never save anything to C: drive on Windows (or any OS's OS drive). Also frequently when I'm working a particular project I save all the various software used for the project to a project folder so everything is nicely organized. With this method I'll have to have files in a totally different location.
Any ideas?
thanks
Keith
jokrmusic
Re: Save as location choice
Post by jokrmusic »
I found out that if you move the file from the folder and then re-open Resolume, you can move it wherever you like.
https://docs.microsoft.com/en-us/window ... -junctions can help you to store your data on another drive.
