Question for setup
Sadler
Re: Question for setup
Post by Sadler »
I can beat that - a masked video with only 2 layers!
Using the (very simple but effective) plugin attached, apply a circle to any clip, set its colour to white, its background to black then set a blend mode of multiply at 0.5 opacity. Then twiddle with centre and radius as desired.
CircleFFGL.zip.zip
Sometimes simple things work best...
(55.04 KiB) Downloaded 372 times
Before anyone asks, I don't have the skills or kit to make a mac version, nor do I have the skills to significantly change the functionality of the plugin. It's a simple circle - that's all.
pavan4
Post by pavan4 »
That worked thanks a lot.
