Just updated to Resolume 6.0.4 and it wont open any of my old compositions.
Attached is the most recent one I used. Seemed to work on 6.0.2 and now it either opens to blank decks or if Resolume is already open, it does nothing.
Transfer Decks from Arena 5 to 6 or from 6 to 5?
- Vjcheshire
Re: Transfer Decks from Arena 5 to 6 or from 6 to 5?
- Attachments
Ocaso Mapped 2.avc- (5.83 MiB) Downloaded 674 times
Yeah, we made a booboo again.
Will be fixed on 6.0.5.
I've got the same problem. Before I couldn't use open file dialog (crashes on Yosemite) but I updated my OS and now when I try to open my R5 comps, nothing happen.
I've a gig on february 10th, do I need to rebuild all my decks or can I expect that 6.0.5 will be released before?
HELP
Thank you
HELP
Thank you
You can use 6.0.3 when you need a quick fix.
Thank you, it works!
