Transfer Decks from Arena 5 to 6 or from 6 to 5?
boris.lema
Post by boris.lema »
Is it possible to transfer Decks i've made from Arena 6 to 5 and from Arena 5 to 6.
thanks!
francoe
Re: Transfer Decks from Arena 5 to 6 or from 6 to 5?
Post by francoe »
Resolume wrote:
Why can't I load my Res 4 or 5 compositions?
It's still a work in progress. In the final release, you'll be able to import all your old comps. Right now, let's focus on what's new instead of what's old!
drazkers
Post by drazkers »
boris.lema wrote:Is it possible to transfer Decks i've made from Arena 6 to 5 and from Arena 5 to 6.
thanks!
Nope, rebuild your deck and report any problems. This is design as 6 is beta and resolume needs every piece of bug data possible.
agentogden
Post by agentogden »
Is this still a lost cause? I have about 100 decks, 1 for each song. Starting over seems a bit ridiculous.
AO
In the final release you'll be able to import Resolume 5 compositions to Resolume 6.
I'm quite sure, that you won't be able to transfer Resolume 6 compositions back to Resolume 5.
drazkers
Post by drazkers »
agentogden wrote:Is this still a lost cause? I have about 100 decks, 1 for each song. Starting over seems a bit ridiculous.
AO
Feel your pain spent a whole day porting my tour comp over. But you learn a lot and make some great improvements. That or as said above wait until it's out of beta.
bilderbau
Post by bilderbau »
hi folks,
new in forum here with v6:
open decks (avc) from v4 t v6 does not work...
should i go over v5 to v6?
old decks from v2 or v3 are probably dead forever
thanx
torsten aka bilderbau
resolume since v1.0
no https in this forum?
no signature?
bilderbau wrote: open decks (avc) from v4 t v6 does not work...
use the Composition menu - open file dialog and then save in R6.
you can open R3 composition in R4 and save, then open the R4 comp in R6., no idea about Resolume 2 comp.
Larshel
Post by Larshel »
Hi, so Ive just started using arena 6, having used arena 5 for a while. I wound like to transfer my arena 5 composition over to arena 6, but when i open the composition it just opens a blank one in arena 6. Someone please help me explain how to do this.
Please send us that composition either attached here zipped or to mail@resolume.com
