Resolume 6.0.9 & Adobe DXV Plugins Released
francoe
Re: Resolume 6.0.9 & Adobe DXV Plugins Released
Post by francoe »
woooo :D
SiNiSon
Post by SiNiSon »
Do we just update reinstall DXV on graphics machines? Or do I need to install resolume on our animation rigs to render out DXV from AfterEffects?
Thx
S
residenthamster
Post by residenthamster »
this is a nice touch, but i'm still on old CS6 and selecting DXV 3 just crashes AME.
fortunately i can still export as DXV 3 by choosing QuickTime and changing the codec.
TVsVeryOwn
Post by TVsVeryOwn »
SiNiSon wrote: Wed Jun 20, 2018 15:56 Do we just update reinstall DXV on graphics machines? Or do I need to install resolume on our animation rigs to render out DXV from AfterEffects?
Thx
S
The DXV plugin is also bundled with the new version of Alley.
Frischvergiftung
Post by Frischvergiftung »
Bravo! Thanks for the Export Support!
julianwilliams
Post by julianwilliams »
RickW wrote: Tue Jun 19, 2018 21:29
Can we get updated instructions on how to export with Adobe Media Encoder? I'm still not seeing DXV3 as an option after the update.
Right here fam: https://resolume.com/support/en/renderi ... v-encoding
Still no joy. DXV3 doesn't appear to be an option. See attached screenshot.
Also having this problem, can anyone shed some light on this?
julianwilliams wrote: Sat Jun 23, 2018 14:39
Looks like AME doesn't create the common folders for Adobe products, and doesn't add registry entries the installer looks for.
Try installing a trial for Premiere pro or AE, and reinstall Resolume.
julianwilliams
Zoltán wrote: Sat Jun 23, 2018 14:44 Try installing a trial for Premiere pro or AE, and reinstall Resolume.
Unfortunately I'm in Guatemala at the moment with very poor internet, can't download jack.
Julian Williams
Lighting | Audiovisual | Design
Planetshakers LD
julianwilliams
Ok, so my stop-gap solution was as follows -
Installed Alley (and exporter plugin) on a friend's computer (who had Premiere installed).
Then went to:
C:\Program Files\Adobe\Common\Plug-ins\7.0\MediaCore
And copied the "Resolume DXV" Folder, to my computer under:
C:\Program Files\Adobe\Adobe Media Encoder CC 2018\Plug-ins\Common
Restarted Media Encoder and success!
Unfortunately as Zoltan said, it appears when you just install Media Encoder it doesn't create the Common directory that the Resolume Codec installer is looking for, so assumes that you do not have any adobe products installed to load the plugin. Would be good if this could be updated in the Alley and Resolume installers to also install to the Media Encoder directory, although this is more of an Adobe flaw than Resolume's issue.
Thanks Guys,
Julian Williams
Planetshakers LD
