A few notes:
1. Use an M2 drive instead of a solid-state drive
2. You might want to check the power consumption of the P2000 cards to make sure the PSU you’re planning is enough. I would think you’ll need at least 850 W
3. My new favorite ATX case is the NZXT H500i
4. The Quadro Sync card won’t work with the P2000, so if you plan on syncing your two cards you have to step up to the P4000
