OSC export of BPM as pulses
OnlineZoltán
- Team Resolume
Re: OSC export of BPM as pulses
If you're using Resolume 7.4+ try this patch as effect on your composition:
- Attachments
- BPM info.wired.zip
- (67.08 KiB) Downloaded 226 times
Nice one Zoltan! I'm so used to pulling from Arena that I forgot you can now push via Wire patches <3
Here's a slight modification I made to also send out the BPM data as well:
https://drive.google.com/open?id=1H9M5Z ... p=drive_fs
OnlineZoltán
- Team Resolume
Ah, yes, I forgot to send out the BPM as number.
Which Wire version did you compile it with?
