OSC export of BPM as pulses
Nackgi
Post by Nackgi »
Is there a way to export BPM clock out of Resolume with OSC? Not as a value of BPM, but as pulses or rhythmically changing values such as the BPM clock in the left side of the Resolume UI.
I'm trying to sync my TouchDesigner patches with Resolumes BPM. I tried to use the BPM value exported from Resolume to generate the pulses in TouchDesigner, but that solution wouldn't want to stay in sync.
Re: OSC export of BPM as pulses
I take Resolume's BPM out and use that as my TD's Tempo then I link Resolume's Re-Sync up to TD and that works well for me.
You can also animate a dummy parameter in Resolume and set it's animate to BPM with a beat count of 1. Then send that out as a custom OSC address in to TD and then apply a trigger or count CHOP with a trigger threshold of .1
The first method doesn't require any additional setup in Resolume other than turning on your OSC output ;)
Nackgi
Post by Nackgi »
Sounds great! Also that dummy parameter workaround sounds like I could use it also for controlling my TD patches with Resolume's external audio FFT.
How do you connect the BPM value to the TD's tempo? I tried to test that but I couldn't find a way to connect a chop to the tempo setting.
Here's a .tox I built for ya. Just make sure Resolume is outputting OSC and set your port accordingly. Now, whenever you change your bpm in Resolume, TD will follow.
I use that parameter animation hack for a LOT of things.
In this example I just used a CHOP exec DAT. Learn to use those! They are VERY powerful tools :)
https://www.dropbox.com/s/x8u0k8m2hl8k8 ... e.tox?dl=0
Nackgi
Post by Nackgi »
Oh nice!
Thank you very much. :)
matinthehat
Post by matinthehat »
I've used Ableton link as a similar solution.
The AbletonLink CHOP has all sorts of pulse beat parameters
Nackgi
Post by Nackgi »
Seems like my version of TD does not have that Ableton Link CHOP yet. :( I'll have to consider upgrading.
Arvol, how do you link your Resolume's resync to TD? I couldn't find any parameter that would "reset" the TD tempo.
I run an independent time chop and use the pulse option for the re-sync
