Capture Card Support for newest AJA and Blackmagic Interfaces
Re: Capture Card Support for newest AJA and Blackmagic Interfaces
jspdyr wrote: Thu Mar 26, 2020 03:44 Does the AJA IO 4K (thunderbolt 2) have the same capabilities as the AJA IO 4K PLUS?
I've been able to use it as 4 SDI inputs, but no matter what settings I tried on the AJA IO 4K, have never been able to use it as SDI outputs.
Which Resolume version do you have?
jspdyr
Post by jspdyr »
Zoltán wrote: Wed Apr 01, 2020 10:48
I'm running 6.1.5 and 7.1.1
jspdyr
Post by jspdyr »
jspdyr wrote: Sat Apr 04, 2020 01:37
I was able to find and play around with the AJA IO 4K today. Have been able to test the unit with gear I have on hand. and I was able to get it to talk with 1 camera on SDI 1 , and two separate outputs on SDI 3, AND SDI 4, in both ARENA 6 AND 7.
