Hi guys, I noticed that the new Aja io 4k Plus is not yet supported. Any idea when that might be the case?
also is the Blackmagic UltraStudio 4K Extreme 3 supported at the moment? need it for a multi camera input set up
thank you
Capture Card Support for newest AJA and Blackmagic Interfaces
OnlineZoltán
- Team Resolume
Re: Capture Card Support for newest AJA and Blackmagic Interfaces
I'm sorry I can't give you an estimate on that, we're working on it.Naigi wrote: Sat Mar 30, 2019 14:33 I noticed that the new Aja io 4k Plus is not yet supported. Any idea when that might be the case?
Ultrastudio devices should work fine in Resolume.Naigi wrote: Sat Mar 30, 2019 14:33 also is the Blackmagic UltraStudio 4K Extreme 3 supported at the moment?
I am working with AJA IO 4k plus. So a +1 to this request.
If you need some QA during this process please let me know.
Right now my team own 2 cards and two licences of Arena, and planing to expand to 4 cards and 4 licenses.
So it would be great to start working with the full setup as soon as possible.
Kind regards,
Felipe
Kind regards,
Felipe
No_sunrise
+1 to this.
Being able to use my Io 4k Plus with Resolume would be dope!
HI
any news on this?
Also I'd love to use the IO4Kplus as output, not as input..is that possible?
Balazs
any news on this?
Balazs
OnlineZoltán
- Team Resolume
We're working on it
#11724
Luxcollective
Any updates on this since August? This would be a killer combo for laptop setups.
T.J.
T.J.
OnlineZoltán
- Team Resolume
The io4k Plus should work as output in 6.1.4, and 7.0.3 and newer.
Does the AJA IO 4K (thunderbolt 2) have the same capabilities as the AJA IO 4K PLUS?
I've been able to use it as 4 SDI inputs, but no matter what settings I tried on the AJA IO 4K, have never been able to use it as SDI outputs.
