Is it possible to get the whole folder somehow and just copy and paste it to the location?
Here is the error:
Installation Error in Resolume Arena
Re: Installation Error in Resolume Arena
- Attachments
- Error.JPG (33.91 KiB) Viewed 5019 times
Thanks, have you installed AE in the default path, in C:\Program Files?
here is a link to the zip
https://www.dropbox.com/s/xpc18a7f9v9zv ... n.zip?dl=1
and where the Resolume DXV folder should go:
Yes. I installed AE in the default path.
That worked! Thanks a lot!
Great to hear that!
Did the Zip work, or installing AE in the default path?
I'm sorry. Missed the last one. The ZIP worked!
Now there is something new. I updated Resolume and the Adobe programs can't connect to the DXV3 codec anymore. Here are pictures. As you can see, everything is still in the same folder as before.
Do you know of any problems like this?
Can you try removing the plugin files from the adobe common folder, then close all adobe programs, and re-install Resolume or Alley?
This can happen when the installer can't overwrite the files because they are in use by Adobe.
