Resolume 7.3.0 update vukan-1.dll is missing
Re: Resolume 7.3.0 update vukan-1.dll is missing
STROP wrote: Mon Nov 16, 2020 10:08 I will send it but who knows when i will get to it :) it is at aweading hall.wich is closed, but now it works fine.
We'd like to prevent this from happening if possible for other users too;)
Which GPU do you have in the machine?
STROP
Post by STROP »
Not really shure, but i eill tell you soon.
#NoTechNoShow Crew - We Make The Shows
www.notechno.show
STROP
Post by STROP »
i have solved the problem
So, the GPU is an AMD Radeon HD 6700
i have sent the report as you asked.
it has my email on it :D
www.notechno.show
Thank you!
We'll see what we can do!
STROP
Post by STROP »
You do not have to.do nothing, it works now :) onley if you need it for your selfs
www.notechno.show
STROP wrote: Mon Nov 16, 2020 11:53 You do not have to.do nothing, it works now :) onley if you need it for your selfs
Yes, for us, and for other users who might run into this otherwise ;)
