Resolume 7.3.0 update vukan-1.dll is missing
STROP
Post by STROP »
Hello
I just updated.my reaolume 7 to the lateat version amd i get an error that is saying vulkan-1.dll is missing. How do i solve this ? Reinstalling the software dose not work the peoblem is still there.
I have an old AMD card and the drivers are up to date.
Re: Resolume 7.3.0 update vukan-1.dll is missing
Try updating the nvidia driver to the latest release from Nvidia directly.
STROP
Post by STROP »
I have an older amd card and it has the latest drivers
#NoTechNoShow Crew - We Make The Shows
www.notechno.show
Which GPU do you have?
Could you install 7.2.1 from the bottom of our download page
and send us the Resolume log file via the feedback tab in preferences?
STROP
Post by STROP »
Hello,
Thank you for the advice, but i solved the problem it seams that somehow in instaling ther update my vulkan-1.dll was deleted.
In order to solve it i had to download VulkanRT-Install, and install it, and it solved my problem.
I will leave a link of the file here if somebody needs it in the future.
https://www.mediafire.com/file/68o363fb ... l.zip/file
If this doese not work vrite me a private message and i will send you the file.
Thanks everybody for your help.
www.notechno.show
Great to hear it's working now!
STROP wrote: Sun Nov 15, 2020 23:03 Thank you for the advice, but i solved the problem it seams that somehow in instaling ther update my vulkan-1.dll was deleted.
You mean the driver update deleted the dll?
STROP
Post by STROP »
I think so, the update deleted the dll cause beafor it was working, and after the update it sayed it was missing. But instalimg vulkan dll installer.solved the problem
www.notechno.show
STROP
Post by STROP »
Sorry, not the driver update deleted the dll, reaolume update deleted the dll
www.notechno.show
STROP wrote: Mon Nov 16, 2020 09:44 Sorry, not the driver update deleted the dll, reaolume update deleted the dll
Older GPU drivers might not have the dll included. AMD has a list of GPU-s which have official support for Vulkan: https://www.amd.com/en/technologies/vulkan
Previous Resolume versions didn't need the dll yet.
Could you please send us the Resolume log file via the feedback tab in preferences?
STROP
Post by STROP »
I will send it but who knows when i will get to it :) it is at aweading hall.wich is closed, but now it works fine.
www.notechno.show
