Resolume 7.3.2 Bug report at startup
zebbler
Re: Resolume 7.3.2 Bug report at startup
Post by zebbler »
Updated the OS to the latest everything, still crashes on startup.
I am gonna go hide and cry now.
Did you also re-install 7.3.2?
What does the mac crash report say?
ynohtna
Post by ynohtna »
I've been experiencing Avenue crashing immediately upon startup this morning (Avenue 7.4.1 76771, MacOS Mojave 10.14.6).
The only thing that has changed on my system since it booted fine was a bunch of old VST audio plug-ins that I installed yesterday (to extract some work from an old project). On a hunch, I cleared out my VST plug-ins folder and Avenue now successfully boots once again.
This might be worth a try for other users experiencing similar problems. Now, time to binary chop these plug-ins to try and isolate the culprit.
The log file should be a lot of help in this.
Check the last line, it should show the last plugin Resolume tried to load.
on win10 : it's in C:\Users\[username]\AppData\Roaming\Resolume Arena
OSX: ~/Library/logs/Resolume Arena/
ynohtna
Post by ynohtna »
Thanks, Zoltán. I found the log through Console.app and determined the bad plug-ins where from Cymatics. I've had their plug-ins crash on me before, so into the trash they go!
