Column Switch - Audio stops for 3 seconds
Re: Column Switch - Audio stops for 3 seconds
Can you share the file which does this for you, with your log file and Documents/Resolume Arena/Preferences/config.xml ?
yollyproject
Post by yollyproject »
vj harald wrote: Sun Oct 10, 2021 12:09 Just want to share my experience
Trigger "mode relative" in a layer with AV clips are not always working, if you fire them via column trigger.
The audio stops for 3 seconds. This happens not every time. In my case every 10 times triggering my clips.
Same with me..i get the issue..Back to resolume 6 the problem gone..
Hans_A
Post by Hans_A »
Zoltán wrote: Sat Jun 04, 2022 09:25 Can you share the file which does this for you, with your log file and Documents/Resolume Arena/Preferences/config.xml ?
Hi Zoltan
Sorry, didn't see your post. Will give you all this info when I have this issue again.
Hans_A
Post by Hans_A »
Hans_A wrote: Wed Jul 06, 2022 21:13
Hi Zoltan
Hi Zoltán
Had a show yesterday with this problem again. Should I send the files to mail@resolume.com?
