Resolume 7.22 Release | Column Power ❤️ Autopilot Improvements 💥 LUTs 🌈 Wire Resources
Re: Resolume 7.22 Release | Column Power ❤️ Autopilot Improvements 💥 LUTs 🌈 Wire Resources
7.22.4 is the fourth hotfix for 7.22 - so not fake no
What are the fixes for the.4 revision?
Resolume Arena 7.22.4 Fri, 7 Feb 2025 17:04:59 +0100 revision 43686
Arena & Avenue 7.22.4 Hot Fix
This update further improves handling of compositions with a lot of layers and columns. It uses less memory, loading and closing large compositions is now faster.
#22673 Inconsistent menu options with multi-selection of clips and empty slots
#22785 Column play button not always showing when column contains persistent clips
#22794 Can't drag original clip off from persistent clip
#22814 Files panel should show video codec too
Arena & Avenue 7.22.3 Hot Fix
#22702 Composition with a lot of layers and columns can take very long to load and close
#22713 High memory usage in 7.22
#22732 MIDI messages can pile up an cause latency with clip transitions
#22763 BPM-synced clips ignore "Active Layer" Clip Target setting when Beat Snap is enabled
#22764 Blend Mode Changes for Multiple Clips Don't Apply Properly or Show Parameters
#22767 AV clips with beat snap can start frozen for some beats
#22768 Group solo makes composition blackout
#22690 Transform widget sometimes misbehaves when monitor is undocked from main window
Wire 7.22.3 Hot Fix
#22766 Texture 2d Channel Causes Monitor Display Issues
Arena & Avenue 7.22.2 Hot Fix
#22739 Low framerates with very big compositions on 7.22
#22716 Arena sometimes crashes with older composition
#22722 Crash dropping file from Finder to Render panel
#22723 Midi shortcut feedback / clip trigger state sometimes not sending out deck switch
#22724 Deck switch should select first column in new deck
#22743 MIDI controller button does not light up when you drag a file to an empty clip that is midi mapped
#22703 Autopilot section should be folded by default on clip panel
#22709 Clip multiselect lost transform effect section delimiter
Wire 7.22.2 Hot Fix
#19844 Snapshot functionality does not adhere to node resolution
#22726 Some patches with resources didn't work in 7.22.
Arena & Avenue 7.22.1 Hot Fix
#22695 Clip Transition can cause unresponsive user interface
#22689 Auto pilot Clip loop not loading correctly
#22692 Edit parameters from multi-selection not working
#22691 Scroll layers and clips into view no worky using mouse
#22693 Clip transport indicator on layers is gone
#22694 Midi mapping for clips with Selected Layer not working
Wire 7.22.3 Hot Fix
Wire 7.22.2 Hot Fix
Arena & Avenue 7.22.5 Hot Fix
- 14855 ProRes playback shifts colors a bit
- 18928 Unavailable Clip menu items should show inactive for clip playing from other deck
- 22880 Fixture for amber/white temperature RGB3
- 22943 Trying to add audio effect from preset to composition not working
- 22954 Column play buttons can show wrong state
- 22988 Composition column play icon not green if only clips in groups are playing
- 22965 Empty column MIDI output incorrect
- 23006 Transitions sometimes not executed
- 23064 Don't trigger column 1 with DMX value 0 on connectSpecificColumn
- 23065 Deselect source clip(s) and select new clip(s) after duplicating
- 23123 Select pasted clip(s)
- 23125 Select new column(s) on column duplicate/copy
Wire 7.22.5 Hot Fix
- 22975 Creating a Polar node from a collection of Shape2D Crashes Wire
- 23009 OSC in should reach all active patches
- 23083 Don't show Display output in OSC/Midi Out nodes
Wire 7.22.5 Hot Fix
Arena & Avenue 7.22.6 Hot Fix
- #23202 Recording on clip trigger does not start if there was already a clip playing in layer
- #23219 OSC Shortcut does not work (initially)
- #23264 Removing last column(s) keeps that column(s) greyed out
- #20744 Recording in h264 not working on macOS
Wire 7.22.6 Hot Fix
- #23225 ISF with still image input crashes Arena
- #23234 Texture In -> Unpack crashes Wire
- #23245 2D render node allows for negative entries - throws errors
- #23247 Cord going to Nirvana
Wire 7.22.6 Hot Fix
Arena & Avenue & Wire 7.22.7 Hot Fix
- #23309 Dongle registration broken on macOS with 7.22.6
Arena & Avenue 7.22.8 Hot Fix
#23271 Shutdown crashes with some compositions
#23330 Moving layer out of group doesn't update layer view
#23334 Duplicated columns have default thumbnails
Wire 7.22.8 Hot Fix
#23265 Editing ISF loses parameters
Wire 7.22.8 Hot Fix
Wire 7.22.9 Hot Fix
#23393 Wire crashes exporting video
