Stuttering Low FPS in Resolume Avenue 7.22
Menno
Re: Stuttering Low FPS in Resolume Avenue 7.22
Post by Menno »
Very interesting read!
Transferring a 20 GB file between them is no issue. Happens quick and transfer rates are 3 GB/s. When I go to move a larger file, like the 90 minute DXV where the file is 500 GB the transfer rate starts super quick and then immediately drops to like 50 MB/s and estimates it will take 4 hours... I waited for a good 15 minutes before cancelling that.
This behaviour is quite common for SSD's, especially larger ones. They only contain a small amount of fast storage and then a slow storage for the rest. When you write a file to it it will write it to the fast storage and then in the background move it over. This works great when files are smaller than their fast storage size, larger files (like the 500GB one) dont fit in the fast storage and thus you're bottlenecked by the slow storage speed.
When I run Avenue and play any of the files (DXV, H.264, 6 or 90 minute) the disk is about 50% utilized as per Task Manager (about 150 Mb/s). Note this speed is the same for any of the file types or durations.
Could you please compare this with Alley? For example when playing from C: causes Avenue to use 50% disk (which is probably Windows' way of saying 100% for 1 out of 2 disks). If you stop playback in Avenue and play that same file in Alley does the file play back better with less disk utilization there? We've done a significant rewrite for alley especially for inter-frame codecs like h264. It will still be a while until we can move Avenue over to the new video engine but it's good to know if we already have a solution for this issue or if there's something else that needs to be done.
F) Would Resolume ARENA perform any different in the entire scope of this issue?
No
G) Odd ball question here but what does the internal Resolume team use for computers?
We get a few new machines each year so we got a wide spread of configurations. For macOS we're using M1 up to M4 for both MBPs and studios. For Windows we use NVidia GPUs but then the consumer level (ie RTX4080). CPU used to be intel (including some xeons) but the more recent ones are AMD.
My office machine is Ryzen 7970x + AMD RX 7900 XT (not because it's amazingly good, more because we need a machine with AMD gpu to test ;) )
I was able to resolve it by moving the content to the other, identical, SSD, D:/
What is the disk's transfer rate when the files are on the other ssd?
Lumenarius
Post by Lumenarius »
Hello Menno and thank you for the follow up!
I appreciate the answers and context for some of the questions I posed.
I read you on digging deeper into the read speed on Alley and also the read speed from the 2nd drive.
I will add those to my list for our weekly check in this week and then report back what I found on those. Will report back in a few days.
ClaudinhoSC
Post by ClaudinhoSC »
I noticed this problem was reported in 2023. I'm still experiencing the same issue today: the FPS drops to 0.8, Resolume freezes, crashes, and is very slow. Any updates on this?
Lumenarius
We found this originally in Dec of 2024.
It turned out to be a slow SSD drive from the computer manufacturer.
We went with a Mac Studio M3 and it fixed everything. Just make sure the drive is plenty capable of playing back high bit rate 4K files and that solved it.
Many other issues could cause this as well. That is just what helped for us.
