New Beta: Resolume Avenue 3 rev1110
johnwhy
Re: New Beta: Resolume Avenue 3 rev1110
Post by johnwhy »
I can't work out the record function...?
All I can find is an option to add a folder for the recorded files...when i press record nothing seems to happen...?
I want to generate a timed record using picvideo.... Like I can in the old version.....?!!
inzieye
Post by inzieye »
where can I find infos about OSC in the manual?
thanks
zieye
incuf
Post by incuf »
YEEES!!! now is working real nice!!!
transport controls on layers, or mappeable active clips button would be good, changing speed of a clip it´s quite difficult if you don´t have it selected.
GOOD WORK!!
cheers!
incuf
GeeEs
Post by GeeEs »
Very Nice! Testing right now... :)
°_Trip_°
Post by °_Trip_° »
New version crashes and the record function doesnt work.... the previous one was excellent
franksentus
Post by franksentus »
I play avenue on my macbook pro with photo jpeg clips but it crashes a lot of time...maybe photo j peg is not the best compression??
it crashes sometime when i change videos or when i change deck..
bye
VibemasterBert
Post by VibemasterBert »
franksentus wrote:I play avenue on my macbook pro with photo jpeg clips but it crashes a lot of time...maybe photo j peg is not the best compression??
bye
the same for me. i feel no difference between the old and new beta - after max 5 minute with my macbook pro i get a crash.
yochee
Post by yochee »
heya great work again edwin & bart. r3 beta1100 is much more stable as you said. no more crashes at playing with the preview monitor etc.
but i am missing:
the help dialog for the recording function (okey its not really complete yet, i see) and a possiblity to change the recording codec: it seems i cant record because i dont have quicktimepro ;)
hironux
Post by hironux »
up and running..... so far, so good.
more plug-ins, PLEASE.
and, version 1.0-we all waiting....
andrei
Post by andrei »
inzieye wrote:Hi,
thanks
zieye
Hi.
I also need OSC manual.
Where is that.
