Hey Joris,
I think if I showed you my log you would probably say 'you should install the correct version of Flash' so I recorded how things look over at my side. Turn the sound down if you want to as it was recorded while screen capturing and not really interesting.
http://youtu.be/fiuEvh5AzQQ
1: Installed Flash Player 10.2
2: Started a .swf file to prove it works
3: Booted up Resolume Avenue 3.3.2
4: Flash files do not work correctly
5: A quick view of what the log says
I have tried deinstalling Flash Player, rebooting and reinstalling but to no effect. Hopefully the video will be more effective than a log. If not I can still send you guys a complete log of course.
Thanks in advance I really love the software <3
~Tino
						Resolume Avenue 3.3.2 Released, Flash More Stable
Re: Resolume Avenue 3.3.2 Released, Flash More Stable
Thanks for the video. We know the logfile says that Flash is not installed while you actually have installed it correctly. We do require the logfile to have your system specs on file, so we know what setup we have to test on
In the meanwhile, have you tried the suggestions in this thread : viewtopic.php?f=14&t=6650&p=29636&hilit=flash+ie#p27656
