Resolume Avenue 3.3.2 Released, Flash More Stable
We are really happy with the stability of Avenue ... except when playing Flash files. But 3.3.2 fixes this. We have a love hate relationship with Flash and it remains an untamable beast but at least it's not crashing Avenue anymore.
A few bugs concerning masks are fixed. Thanks to Helder Freitas you can now enjoy the Resolume interface in Portuguese and a few other bits and bops are fixed too.
Resolume Avenue 3.3.2 release notes
[fixed] Flash instability
[fixed] Portuguese Translation by Helder Freitas
[fixed] MIDI or DMX deck switch deadlock
[fixed] Effects linked to dashboard reset to default value on startup
[fixed] 3 part OSC position messages to audio/position/values crashes Avenue
[fixed] Column names disappearing (again)
[fixed] DMX clip trigger mapping is not saved in composition map
[fixed] Luma Key: White still visible at 0%
[fixed] Memory leak in file browser when set to thumbnail mode
[fixed] Loaded AFX that are bypassed cause audio-drop out when un-bypassing them
[fixed] Strobe effect on resized clips displays incorrect
[fixed] Masks are not applied correctly
[fixed] Clip with mask not displaying in output window when triggered
[fixed] Clip displays wrong mask
[fixed] Clips triggered by DMX ignore the layer target setting
Download & Enjoy!
The Resolume Team
Edwin Bart Dani Tim Joris
GeeEs
Re: Resolume Avenue 3.3.2 Released, Flash More Stable
Post by GeeEs »
:) Super!
francoe
Post by francoe »
Some time ago I've discarted all my flash footage.
Well, is time to play again! :D
Tino
Post by Tino »
Sweetness! Hopefully Flash will now work the way it was meant to. It used to just show the first frame and nothing and jam there. I'll let you know if this is fixed this new version :D
YIIHAAAA!
Godzil
Post by Godzil »
bart wrote: [fixed] Luma Key: White still visible at 0%
Good one!
Tschoepler
Post by Tschoepler »
:D thanks
Tino
Post by Tino »
After some poking and trying I still can't get Flash to work for me. Not video's, text or anything. I have tried this in the 3.3.1 and 3.3.2 version with the latest Flash version. Would you like me to record the process so it might help you pinpoint the problem?
~Tino
Hey Tino
We've indeed had some reports of Flash still being problematic for some people. Screencaps are always welcome, but your logfile would be the most helpful. You can send it to us via the Feedback tab of the preference.
Basic
Post by Basic »
Gentlemen! Thank you! just got it installed and going to hit up some flash stuff! first for everything! :)
