flash using rparameters
levon_
bsom_
Ruud_
I used the bars.fla example and I also defined
var rparameterleft1;
but not the part of
rparameterleft1 = 0;
my only problem is that I can't use actionscript while looping timelines. At the frame where I have set an actionscript like _root.bar1 blabla = rparameter1 * 15 my loop hangs at that frame and only respons to the actionscript. So my timeline does not loop anymore!!! That's bad!!
I want to loop shape tween and or motion tween and at the same time scale and or alpha tween my objects!!!
anyone have any idea?
levon> just see the bars.fla in you resolume programfiles /flash map
greets!
but not the part of
greets!
Ruud_
