first your manual page says the variables are capitalised, and flash MX is now case sensative, so the help file should be fixed please.
anyway, im having trouble accessing the variables, if i put them as a text feild like in the demo file it works right away, but when i use them as a variable in some action script it doesnt seem to work.
i dont want to give away what im making till its finished, and i will share it with everyone.
im using it as a direct variable, assuming it just sends the variable to flash as a number it should work with myfile.
thanks, and if anyone else has made any files that use the rparameters from resolume ild love to see what you have done.
flash using rparameters
levon_
oh and ive tested, if i declare what rparameter1 is at the start of the flash file as 40 it works, so the error is coming from somewhere in the way resolume sents the value to action script, but not the text, cause in the same file i have a working text feild that displays the current value of rparameter1
hi levon,
i made an example .fla document.
this is how we use the variables in resolume.
make sure you set the timeline mode of the channel to flash.
flash anim
i exported it to flash 5 so i hope most people can open it.
cheers
flash anim
cheers
levon_
ok i got it working, thanks for teh info edwin.
ok here is what ive been working on, its not much, but it works. although it just looks black, save it, and open it up in resolume 2. and make sure you have the music stuff set up
- Attachments
[The extension swf has been deactivated and can no longer be displayed.]
levon_
levon_
Ruud_
levon_
you have to open up the sound thing in windows (little speaker icon on start bar) double click it.
goto options-Properties and change the adjust volume for: to recording and make sure wave or CD audio what ever the source is ticked in the little space below. click ok.
now the mute tick box should be called select. tick the one you want to play into resolume.
