first of all i thank you for taking your time to read this.
My problem is that i just bought a new laptop sony vaio: SVE14125CLW with Core™
i5-3210M, 2.5GHz,
AMD Radeon™ HD 7550M, 1GB,
4gb RAM,
and WINDOWS 8,
The thing is that I have read the post named "strobing screens in advanced/fullscreen - catalyst 12.6"
posted in this forum, i got the same problem, fullscreen output display makes both screens strobe, windowed mode doesnt do it.
i tried to fix this following the instruccions, but it seems this only works in windows 7 because you can check "disable desktop composition" and "disable windows themes" in compatibility in this OS, but it doesnt work in wndows 8 beacuse the OS needs to have this functions to be active all the time!!!.
i cant downgrade to windows 7 for now beacuse the model of my laptop is too new that it doesnt have the drivers that support the same functions.
what can i do?? im starting a small business and i wanted to buy the full version but i need this problem solved first to make sure that i can use this laptop that i bought specially for work...
i nee resolume working fine in this laptop :/ help me, and again, thanks for reading me. Merry christmas
