I would like to know which format you recommend I save out of After Effects to then use Streamclip to convert to a Quick Time movie using DXV for the best performance in Resolume.
Best format to export from After Effects
Re: Best format to export from After Effects
Why not render directly to DXV??? You keep the AE project and if you need one day a diferent codec, you can render again the file...
Thanks, did not realise I could do that
