BPM Random Parameter
It would be great to have the option of random in addition to the loop and pingpong modes of BPM synced parameters. I'd like to have the ability to jump to a new random value on each beat or multiples there of.
theLABVisuals
Re: BPM Random Parameter
If you set the clip transport to BPM sync, then you can select random playback. Just set the Beats to the required length. This only really works with longer clips mind. Something too short will just look a mess (IMHO).
I think Sleepy is talking about having that option for parameters as well, not just for the playhead.
Any takers for a +1 killing spree?
sounds crasy... I would push the button! +1
Do you like outlines? Easy Outliner on Juicebar - Tschoepler
