Flash not able to load xml/images on Windows Resolume Avenue
Gerarddus
Post by Gerarddus »
I've been trying out Resolume Avenue 4.1.3 on a Mac with some flash files (CS5).
I've built a small flash-test which loads an xml-file, and then loads the images mentioned in the file.
That is working just fine on my Mac, but as soon as I want to play the same flashfile on a Windows7 Resolume Avenue, it will not get past loading the xml file, and if I skip that and load an image directly, it will not do that either.
Is there something I am missing?
I'm attaching the swf with xml and images if you care to take a look.
Gerard
resolume_test.zip
flash file with 5 sample images and xml.
(868.77 KiB) Downloaded 702 times
Re: Flash not able to load xml/images on Windows Resolume Av
Do the Flash files that come with the demo work correctly on the PC? If not, you might need to install Flash Player for Internet Explorer, that seems to fix a lot of Flash issues on the PC.
Gerarddus
Post by Gerarddus »
Thanks for your answer.
Yes they work on the PC in a browser. I reinstalled the flashplayer for IE to try again, but still no xml and images load.
Sorry, I'm afraid I've been unclear.
I meant to ask if the *Resolume demo Flash files* work correctly in Resolume, not whether your own files work in the browser.
Gerarddus
Post by Gerarddus »
AH! Yes I've tried those. Interestingly enough, the original twitterBoxes.swf works fine on Windows, but if I export the twitterBoxes.fla on Mac to swf and try to load those on Resolume Windows, it does not work.
I am using Flash CS 5 by the way.
And I've also installed a demo version of Flash CS6 on windows, and that results in the same problems. Neither my exp.swf nor a newly published twitterBoxes.swf works within Resolume.
I'll try on another windows computer next week.
Gerarddus
Post by Gerarddus »
I've tried the flash-files on two other windows 7 computers. On one it worked, on the other, it didn't. Both computers had the latest flash player installed. Does anyone have any idea what could make the difference besides the flash player?
HerrNieDa
Post by HerrNieDa »
i also got Problems with Flash, on the one computer it works, on the other it does not!
also tried reinstalling flash player etc...
