I've just upgraded the GPU I'm running Resolume (4) on from a Quadro 5000 to a K5000 which is a significantly faster card but Resolume seems to actually be running slower. Could there still be some driver optimizations to be done yet?
thanks
Keith
						Quadro K5000 not running as fast as Quadro 5000
Re: Quadro K5000 not running as fast as Quadro 5000
Thought I should post this update for any other Quadro users out there. It turns out it was the driver. I updated drivers when I installed the card and it seems that what was causing the problem. Driver 310... does not work as well with my setup but driver 307.45 is fine.
I have a relatively complex setup so others may not have the same problem anyways. I'm running Resolume on GPU0 while at the same time running Touch Designer on GPU1 using GPU affinity along with Quadro SDI capture and sync cards. Resolume is then sending its output via sharedmemory to Touch Designer. I realize there is a lot of room for error but everthing is work fine now that the driver has been rolled back.
cheers
Keith
cheers
Keith
