Best Software converting to DXV?
Which is the best software converting videos with the resolume dxv-codec? (maybe wih support of CUDA or any other special GPU-Support)
| EVGA SR-2 | 2 x Intel Core i7 X5650 | 48 GB Corsiar DDR3 PC12800 | 2 x HD5870 Eyefinity 6 | 1 x GTX580 | 256GB Samsung 840 PRO | 160GB Intel Postville | Win 7 X64 | Resolume Arena 4 |
Re: Best Software converting to DXV?
Encoding happens on the CPU, nothing to do with GPU and of course with Cuda.
The best encoder imo is Streamclip, and it's free...
there a some tools using GPU... but most of them can´t handle DXV.
But, whats the best one and supports multicores? (more than 4
But keep in mind, that MPEGStreamclip cannot handle the alpha channel (when encoding to DXV)! Also I experienced that it's not possible to encode more than one video at the same time via batch encode. Streamclip or DXV encoder (maybe both?) are not thread-safe.vj granda wrote:Encoding happens on the CPU, nothing to do with GPU and of course with Cuda.
I lost some hours to find this out... I think the missing alpha support is even mentioned in the Resolume manual, though I'm not sure.
The batch list works ok for me on mac. Sometimes I get an error on one file that doesn't got converted but when I try that one again it does convert.Rene wrote: Also I experienced that it's not possible to encode more than one video at the same time via batch encode. Streamclip or DXV encoder (maybe both?) are not thread-safe.
Adobe Media Encoder CS6
