[resolved] Layer transform presents...
trugoy1111
Post by trugoy1111 »
Hello,
I am working in Arena and need all new clips I bring into layers to have the same exact global settings or properties as the previous clip on the layer. I love the fact that I can call up effects presets I have saved and apply them to the next clip but it seems that I dont have this option in the transform section.
I am working with many layers that need to remain in the same position for my show and I have spent quite some time getting them cropped, masked and anchored into precise positioning.
Do I have to pre set everything up in the transform positioning for each and every clip in my layers or is there a way to copy ALL my settings to the next clip in layer order?
Any help would be appreciated.
Thanks,
Todd
theLABVisuals
Re: Layer transform presents...
Post by theLABVisuals »
I do believe I asked the very same question in October, and the clever folks at Resolume came up with this answer :)
viewtopic.php?f=6&t=9841
Creativity, Imagination, Inspiration, Caffeine.
At least I can rely on one of them
http://www.thelabvisuals.co.uk/
In this particular case, I'm wondering why the transform controls on the layer level are not an option?
Rene
Post by Rene »
For me the layer is not an option (at all most of the time) because I would need the layer options per deck. Right now if I switch decks, the presets from deck A make no sense if they are applied to deck B, same with the layer names.
On the other hand I see that a single fx-layer for all decks makes sense e.g. for transitions. ;)
trugoy1111
Thank you so much for responding so quickly. Each of your answers helped and gave me several ideas to get to my final desired goal.
