Firstly, just want to say hello to all.
Secondly, I am completely new to the VJ world.
I have been tasked by a client to map a car for an event they are having and I am finding certain things rather tricky, so hopefully I can get some advice from the pros.
My first issue is simple enough I guess but beating my head so many times has damaged the logic in me....What would be an efficient way to align the projector and car into the scene?
I have taken a picture of the vehicle in the perspective of the projector but once designs are complete the alignment is out of sync...I have tried to read up on this but no luck really (logic cells are fried).
My other issue is that the graphics I create is pixelated when projected...could this be down to the codec?
Any advice would be greatly appreciated!
Oh no Im a Noob..Help
Re: Oh no Im a Noob..Help
Well, I never mapped a car before ; )
Let´s start from the end.. pixelating: check projector resolution and pixel aspect (4:3 or 16:9); also, what is your composition size in pixels and what is your footage resolution? Yes, a bad encoding can also produce artifacts and pixelizing, but you would also notice that out of projection.
Alignment out of sync: that´s all about mapping. There´s no magic on it. No matter how precise is your setup you will allways have to move a couple of points to make your projection to fit properly.
Specificaly mapping a car, you must realize that a car is 'almost' an 'organic' object, I mean, they are smooth, full of curves and angles. The best (utopic) way to map a car is to create your video footage based on a precise 3D model of it. I mean you have the 3D model of the car, then you surface it, animating the effects the way you want, position your virtual camera at the same position (in the 3D space) as your real camera is positioned in real world, and render!!!
You are completely new to the vj world, and you want to create the content and mapp a car??? It's a joke, Isn't it???
Thanks pfelberg for the feedback. I managed to get a decent workflow that suits my needs.
vj granda...when I say new to the VJ world I mean I am new to using software such as Resolume, AE etc and make it work with a live audience and live music.
Certainly not new to creation of content.
In the end though, I made it work rather well I think and will be displaying it at an event this weekend.
Good luck with your mapping, TheNutter.
I would like to see some video of the final result.
Cheers
Cheers
