Hey Dudes!
I'm looking for an audio reactive flash file like an equalizer or something.
I found a few things here at this forum but nothing really works with Arena.
I just need 3 simple rectangles which are responding to bass, mid an high levels.
Could someone send me such a flash file?
Equalizer - Audio reactive flash
Re: Equalizer - Audio reactive flash
Flash is dead
Here's a Resolume composition file that does exactly the same thing.
- Attachments
3 Band EQ.avc
- (34.82 KiB) Downloaded 2100 times
Hm, that's a bit helpful. But if i want to have more 'blocks', then i do Need more Layers? So, if i want a 7 Band EQ, then i Need 7 Layers...
I would be very happy if there is a plugin that simulates a real EQ with much more bands in only one Layer...
Madrix does it excellent. But i don't want to have another Software for my Screen and do not want to spend so much Money for just this tool...
Greetings from Germany
Rainschn
Rainschn
If you're happy to use audio from the default device rather than Resolume then Alex May's power spectrum is very configurable.
http://www.bigfug.com/product/ffgl-powe ... r-windows/
Yes! Thank You! I found it myself as well in another Thread and i'm very happy with it!
Rainschn
Rainschn
Is there something like this for Resolume 7?
I've sort of done my own by placing a solid green/yellow/red image as the base layer, then adding several layers of BLACK solid colours over the top with animation to FFT to shift it vertically with the Audio input, but a bit cumbersome.... would be good to just have one clip to play, rather than having to start a whole column.
Excellent, cheers for that. I've installed it and run on my Mac, will it work on windows too? I guess I need to install this juicebar program on the windows machine, and install that plugin there too?
