Has anyone successfully used Turnado from Sugar Bytes with Resolume?
I'm trying it on a mac/Lion. I can drag it onto a clip ok but when I try to open the gui Avenue crashes.
Can anyone else try it out?
Edit - I should add that it does work audio wise but you can't use the GUI which makes it nigh impossible
						Turnado VST
Re: Turnado VST
Seems to work on Windows though - not tested thoroughly.
