processing in resolume
MinimalicQuantum
Post by MinimalicQuantum »
Hi.
does anyone knows how to import processing projects to resolume arena...?????
Re: processing in resolume
I would like to know this too ;-)
:? processing projects???
arindamliveguitar
Post by arindamliveguitar »
you want to import a .pde file??
MinimalicQuantum
arindamliveguitar wrote:you want to import a .pde file??
yep .pde projects in layers so i can mix them down from resolume....
MinimalicQuantum
in processing forum they said that you can do that by importing code for syphon so you can connect it through resolume...
but i think this is a pain in the @ss for doing this for each .pde project separate
MinimalicQuantum
MinimalicQuantum wrote:in processing forum they said that you can do that by importing code for syphon so you can connect it through resolume...
viewtopic.php?f=6&t=6702&p=25459&hilit= ... api#p25459
Short answer is, we'd love to do it, but it's not as straightforward as you think.
tannerlthompson
Post by tannerlthompson »
This is the basics for working with syphon and processing...
import codeanticode.syphon.*;
PGraphics canvas;
SyphonServer server;
void setup() {
size(400,400, P3D);
canvas = createGraphics(400, 400, P3D);
// Create syhpon server to send frames out.
server = new SyphonServer(this, "Processing Syphon");
void draw() {
canvas.beginDraw();
canvas.background(127);
canvas.lights();
canvas.translate(width/2, height/2);
canvas.rotateX(frameCount * 0.01);
canvas.rotateY(frameCount * 0.01);
canvas.box(150);
canvas.endDraw();
image(canvas, 0, 0);
server.sendImage(canvas);
tannerlthompson
PGraphics canvas; //this names the image being sent out as canvas... you need to lable all visual things with canvas.line(); ect...
Then at the end :
This outputs all things labled with canvas. as a syphon stream and will show up under sources in resolume
