1. I import a video on reolume.
2. Then in Premiere I render the video again wit different resolution and pixel size and overwrite the old file.
3. I go to resolume and change settings clip.
4. The video only shows it's correct size or proportion, if I clear and import again.
5. Is there a REFRESH option due to not have to clear and import again?
Refresh Clips
Electroguepard
Re: Refresh Clips
Resolume updates the content when the deck containing the content is opened. So make sure the file is not playing, switch to a different or empty deck and switch back again.
Electroguepard
Re: Refresh Clips
I recorded a clip, when I can I upload it, showing the problem.
