Need help to configure a new PC
darq
Post by darq »
we are pretty new to Resolume but we decided to invest in 2 Beamers, a triple head2go and a Pc to do some nice visuals at our Partys.
We want to run Full Hd videos and want to be able to do alot of mapping on both projectors.Are there any suggestions which gpu/cpu we should go for?
Do you think a geforce gtx 680 , intel i5 ,8 gb ddr3 and a SSD drive will do the job ?
thx for your help
Alex
Re: Need help to configure a new PC
simlpy...yes! :)
darq
Post by darq »
do you think the configuration is ok or is it way to high and we could also go for something cheaper ?
Would it also work with 3 x full Hd ?
3xHD DXV out will work with your system. And maybe a cheaper system will also do the job...but not much cheaper ;)
darq
Post by darq »
ok thank you very much so i think to have some extra performance is never a bad idea so we better go for this one.
thanks alot :)
GO GO GO! :P
HerrNieDa
Post by HerrNieDa »
for example you can save money by buying a used one gtx580... should be about the half price of the GTX680 and should also do the Work.
